Текущее время: 26 ноя 2025 05:21
Форум СТРОГО МОДЕРИРУЕТСЯ.
Обязательно указывайте модель, год выпуска,VIN, местонахождение, пробег, комплектацию, цвет и цену.Ссылки на сторонние ресурсы запрещены!
Фотографии желательо!
Объявления, размещенные с несоблюдением этих правил, как и содержащие ссылки на аналогичые ресурсы, удаляются без предупреждения.
 Chevrolet Chevelle California Malibu
Новое сообщение Chevrolet Chevelle California Malibu
This exceptionally maintained California Malibu has been totally restored to the last "Nut & Bolt", refinished and modernized in many areas giving it a classic but clean look. This example features show-quality black paint, a 350 Cid V8 engine 447hp & 454ft-lbs built and dyno tested by Jomar Racing Detroit Michigan, with 6 speed Richmond transmission, 12 bolt posi-traction, power windows, power locks, power trunk, 16" aluminum wheels, power four wheel disc brakes, 3" stainless steel dual exhaust, powder coated frame and suspension, air conditioning, tilt steering, keyless entry, theft alarm. Interior features a custom brushed stainless dash panel, Grant billet steering wheel and vinyl front Cerullo bucket seats, AM-FM CD radio. Professional and careful attention to detail is evident in every aspect of this vehicle with no expense spared truly one-of-a-kind! This car is ready for shows or cruises with lots of fun. 2000 miles since the build. Please email if you have any further questions.
Drive Train
-447hp/454ft-lbs torque V8 powder coated block and heads
-aluminum heads and intake
-6spd Richmond transmission
-Lakewood scatter proof bell housing
-Centerforce dual friction clutch
-12 bolt posi-traction with 3.73 gears
-Bear’s c-clip eliminator kit
-Strange pro street axles
-Baer Claw 4 wheel disc brakes
-electric vacuum pump power assisted brakes
-March aluminum serpentine pulley set
-AED 750cfm Holly carburetor
-polished aluminum water pump
-MDS 6AL ignition with an Accel high out put distributor
-billet aluminum air cleaner and engine breathers
-Borla 1 5/8" stainless steel headers
-3" mandrel bent dual stainless steel exhaust with Borla XR-1 racing mufflers
-Torque Tech 3" mandrel bent aluminized tail pipes powder coated
-Energy polyurethane engine and transmission mounts
Chassis
-frame and all suspension components are powder coated
-Hotchkis tubular front upper A-arms
-Hotchkis rear boxed upper and lower trailing arms
-Hotchkis progressive rear coil springs
-Hotchkis 1 1/8" front sway bar
-Hotchkis 7/8" rear sway bar
-Hotchkis trailing arm braces
-Koni adjustable shock absorbers (rear)
-Pro-shock front adjustable coil over shocks (front)
-complete polyurethane suspension and body mounts
-Flaming River manual steering
-Be Cool aluminum radiator
-electric fan with thermo switch and relay
-powder coated fuel tank
-heavy duty aluminum differential cover
-battery mounted in the trunk
-16" Center Line Thruster aluminum wheels
-P255/50ZR16 BF Goodrich Comp T/A ZR rear tires
-P245/50ZR16 BF Goodrich Comp T/A ZR front tires
Interior/Exterior
-custom brushed stainless steel dashboard
-Pioneer AM/FM CD radio
-custom front kick panels with a Focal component set
-rear pioneer 4-way 6x9 speakers
-Kenwood amplifier
-power antenna
-Auto Meter ultra-lite gauges
-Vintage Air air conditioning system
-Painless wiring harness and fuse panel
-custom mounted hand brake
-Cerullo high back bucket seats
-custom rear bucket/bench seat
-power windows
-power trunk
-fluorescent trunk light
-all new exterior trim
-original bumpers professionally refinished
Цена вопроса 85 000 $
Писать сюда: chevmalibu1967@ymail.com
Зовут Мартин (Martin) автомобиль находится в Канаде.
01 мар 2009 22:09
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 80
