Текущее время: 14 окт 2025 03:23
 Центральный замок
Откуда (Страна, Город): Россия Смоленск
Новое сообщение Центральный замок
Всем привет! Подскажите, купил новый брелок центрального замка H2 (сигналки), как запрограммировать его к машине? Заранее спасибо.
С уважением Сергей.
13 мар 2013 15:40
Новое сообщение Re: Центральный замок
Брелок Хаммер Н2 2002-2007 года:
You must have all remotes including working ones when performing this procedure.
1. Close all doors.
2. Insert key into the ignition.
3. Press and hold the power UNLOCK button on driver's side door panel. Do not release until instructed to do so in step 5.
4. Quickly turn the ignition ON, OFF, ON, OFF. (ON is the position just shy of starting your vehicle, OFF is the position where you can remove your key)
5. Release the power unlock button on the driver's side door panel. The vehicle should respond by locking and unlocking automatically. If locks cycle then continue to step 6.(if the door locks begin to lock and unlock BEFORE releasing the unlock button then the vehicle has not entered programming mode and you must start over. Remove key, open door and return to step 1. If the vehicle continues to lock and unlock before releasing the unlock button then there is a problem with the vehicles system and remotes must be programmed by a certified professional. If you are unable to get the door locks to cycle then you are turning the key too quick, too slow, there's a problem with the vehicles system, or the vehicle is not equipped with a factory keyless entry system.
6. Hold the LOCK and UNLOCK buttons on the remote at the same time until door locks cycle again. This could take up to 30 seconds.
7. NOW repeat step 6. for all additional remotes including working ones.
8. After step 6. has been performed for all remotes TURN ignition to ON to exit programming mode.
9. Turn ignition to OFF, remove
13 мар 2013 17:06
Брелок Хаммер Н2 2008-2009 года:
PROCEDURE #1
THIS PROCEDURE IS FOR VEHICLES WITH THE DRIVER INFORMATION CENTER. IT WILL BE A BUTTON TO THE RIGHT OF THE STEERING WHEEL WITH A VEHICLE ICON AND THE LETTER i.
1.Insert key and switch the ignition ON (just shy of starting vehicle without cranking engine)
2. Press vehicle information button until PRESS TO RELEARN REMOTE KEY is displayed.
3. Press the set/reset button (button will have a checkmark) until REMOTE KEY LEARNING ACTIVE is displayed. Vehicle is now in programming mode.
4. Press and hold LOCK and UNLOCK buttons at the same time on first remote for approximately 15 seconds. An acoustic signal will be heard indicating successful programming.
5. Repeat step 4. to program additional remotes. You can have up to 8 programmed remotes for this vehicle. You must program ALL remotes including existing remotes.
6. To exit programming mode turn ignition OFF, remove key and test all remotes.
PROCEDURE #2
THIS PROCEDURE IS FOR VEHICLES WITHOUT THE DRIVERS INFORMATION CENTER.
1. Insert key into the ignition and turn to ON (Just shy of starting vehicle without cranking engine).
2. Press the trip odometer reset button until RELEARN REMOTE KEY is displayed.
3. Press and hold the trip odometer reset button for approximately 3 seconds until REMOTE KEY LEARNING ACTIVE displays.
13 мар 2013 17:07
Ключ 2008-2009 года выпусков. До этого года ключи были без чипа, как и некоторые рестайлы:
ADD DUPLICATE KEY (REQUIRES AT LEAST ONE WORKING KEY)
1. Verify that the new key has a "+" stamped on it.
2. Insert the original, already programmed key in the ignition and start the engine. If the engine will not start, see your dealer for service.
3. After the engine has started, turn the key to off and remove the key.
4. Insert the key to be programmed and turn it to on within 10 seconds of removing the original key.
5. The security light will turn off once the key has been programmed. It may not be apparent if the security light went on due to how quickly the key is programmed. If your vehicle does not have a security light (04-07 Grand Prix, Bonneville, Impala) wait 10 minutes and 45 seconds to make sure the key has been programmed.
6. Repeat steps 1 through 5 if additional keys are to be programmed.
13 мар 2013 17:09
Полезная инфа!
Отмечусь, вдруг когда пригодится.
Изображение HUMMER H2 2008г.
13 мар 2013 19:26
Кому надо есть на русском ))
15 мар 2013 00:45
Skif8814
Выкладывай! Я поленился переводить)
15 мар 2013 07:16
Спасибо всем. Перевел все получилось. Брелок работает.
С уважением Сергей.
16 мар 2013 17:18
Незачто!)
18 мар 2013 12:58
