ДИФФЕРЕНЦИАЛЫ Н-1 ТИП И ПРИМЕНЯЕМОСТЬ
Добавлено: 06 ноя 2010 20:54
AMC Model 20
Perfectly round rear cover with 12 cover bolts. Has bolt in axles which are a 2 piece design from the factory.
•Ring Gear Diameter: 8.5
•Ring Gear Bolts: (8 or 12) 7/16 x 20 RH
•Cover Bolts: 12
•Carrier Breaks: 2.76 / 3.07
•Spline Count: 1.625 / 28
•Float: SF
•Semi-Float Type:
•Pinion Support: False
•Axle Lugs: 5 and 6
Compatible with Models: Catalina: 1940 - 1940 (Rear)
CJ5: 1976 - 1983 (Rear)
CJ6: 1976 - 1983 (Rear)
CJ7: 1976 - 1986 (Rear)
CJ8: 1981 - 1986 (Rear)
H1: 1980 - 2006 (Front)
H1: 1980 - 2006 (Rear) Matador: 1971 - 1978 (Rear)
Wagoneer: 1980 - 1992 (Rear
•Cover Bolts: 12
•Float: SF
•Semi-Float Type:
•Axle Lugs: 5 and 6
